Hello,
I need to reset the gear linkage on an 06 Corsa C and would like to confirm I am going about this correctly.
Firstly, I bought a T50 Torx to undo the clamp attatching the gear change rod to the gear change mechanism only
to find the torx has been replaced by a nut and bolt. Thats assuming I'm looking in the right place. Could
someone please confirm that the bolt in the photo is the correct one to undo.
Also I have an issue locking the gear stick in position. I have seen two methods to do this. One is to
remove the gear knob and the raise and rotate the plastic clip ninety degreees with the gear stick in neutral.
The plastic clip on mine is damaged so I dont know wether to do that or use the second, which is to align the
two holes and insert a screwdriver. However on mine that would put the gear stick in second gear and over to
the left. Is that the reset position? If not I'll assume I need to raise and rotate the clip.
Hope that made sense.
Best wishes,
Best wishes,
