Giving Up with Breaks
1 reading
581 views 7 replies 4 participants last post by  Ruined
#1 ·
Hello Guys, sorry to bother you gain but I have a problem with my brakes.
First I thought it would be simple, but now it is getting more serious; had my brake pedal vibrating while I slightly push the brake pedal, went to vauxhall dealer once they worked on my front rotor(machined) and after then they worked on my rear rotors(machined) and in the end still having the break pedal vibrating at high speeds over 100 Ml/h.
went again to the dealer and they told me it is not advised to get my rotors machined although they told me to get my front and rear rotors machined, and I should change them with a new pad set.
I changed the front rotors, got a new front brake pads and guess what I still having that annoying vibrating(still the same).
now they want to change the rear rotors and I do not believe it is the reason.
by the way I got my wheel aligned also wheel balanced so I could eliminate the problem.
what do you advise ??
do I change the rear rotors(drums) or it is not the reason and I should look some where else ?
and could it be something else the rotors making my break pedal vibrating at high speed when I slightly push it.
#3 ·
No, there isn't.
but before I change rotors and pads there was a metal hit while I'm breaking because there were some shims missing frome the pads; but it was done after I got the pads with the new shims.
#7 ·
Re-bleed your system?
Probably something to do with your drums at the back tbh
