I have just purchased a road angle speed camera detector and do not want to have it plugged into the cigarette socket as I need that for my sat-nav. Is it easy to hard-wire a cable in so its always on..?
yeh its relativly easy mate, take the lead that comes with the road angel and tuck it down the side of the windscreen in the little gap, then take it down the side of the door, under the footwell, and try and get it behind the back of the center console were the cigarette lighter is, then use a screw driver to prise the cigarette lighter cover off (were it plugs into)and connect the cables into the back of the terminals. youl be best taking the cigarette cover off before trying to feed the cable down the centre console!!
this way, everytime you turn your engine on, your road angel will turn on.
Banned
ive done mine if i get a chance ill get pictures on how to, tommorrow
:thumbs:
you can get a seperate lighter socket to wire up (as above) from halfrods for £5
then you can simply plug the road angel in. just need to take the a pillars ang glove box out to feed the wires down ;)
