I think i might have a head gasket problem, not sure tho because im loosing oil but not one bit of water?
I thought ud loose both if the head gasket was on its way out?
Im gonna change it anyway, just wondered if it could be anything else?
Its not leaking anythin either :shock:
Probably not then. Get a pressure test done.
Get a compression test done on each cylinder. You may find one or two that has lost a bit of pressure. Now if your losing oil, it could also be the piston rings have worn. To find out, squirt a tad bit oil into the cylinders thats low on pressure. This will form a seal around the piston rings, and the compression should rise. If it does, then the piston rings are fooked. If it doesn't you need a new head gasket.
:doublethumbs:
Cheers for the replys, im gna get a compresion test done n go from there. I recon im gna change the piston rings and head gasket anyway just to be sure.
Anyone know where i can get a compresion test kit from, halfrauds?
