Help!, Loss of power issue
722 views 3 replies 2 participants last post by  corsaz22se
#1 ·
Hey everyone, I'm reaching out because I've run into a bit of trouble with my Corsa recently, and I could really use some advice or assistance.
Lately, I've been noticing a significant loss of power while driving, especially when accelerating. It's been quite frustrating, and I'm not exactly sure what might be causing it. I've checked the basics like the fuel and air filters, but I'm not having much luck. i've tried to fix it myself in using an engine cleanner to cease the problem but sadly, there's no a satisfactory results so i'm wondering if any of you have experience with similar issues or have some mechanical expertise, I would greatly appreciate any insights or suggestions you might have. I'm hoping to get to the bottom of this problem as soon as possible so I can get back on the road safely.
Thanks a lot for your help in advance.
#4 ·
They don't do a 1.2 3 cylinder?? Its either a 1.0 3 cylinder or the 1.2 4 cylinder.
As for the oil as you are in a warmer climate I would go For a 10w40 or 20w50 oil depending what part of Australia you are in? Most of it is warmer than the UK and there you only need the thin oils in winter really.
Which ever size engine you have it will be I assume a "twinport" with a timing chain. It could be a number of faults. It's quite common for the coil packs to fail and as they do the engine losses power, for the twinport activation valve to stick, the rail link to break and this will cause power loss (you normally hear some kind of clicking sound from the back of the engine just below the cam cover area), the MAF sensor to fail, timing chain to be stretched and skip a tooth (usually they are quite rattly first), also for the throttle pedal and or wiring to play up, there is a plug in the drivers side kick panel with the junction between the pedal loom and the dash loom, check here for poor connections or corrosion on the pins.
My first step would be to use a diagnostic tool to scan for fault codes and read the live data from the car if you don't have any strange sounds from the engine that is?
How is it starting both hot and cold? does it ever stall easy? If so it may be the crankshaft sensor which is next to the starter motor and access is from under the car.
I would also recommend trying a high octane fuel I think from another post recently you guy get a 91ron, 95ron and 98ron fuel? The 98 is much better for the engine and back home we have a 99ron which is what I use and it returns much better MPGs, like 5 MPGs more than the 95ron so even though it costs more per litre it works out less ÂŁ/mile over all.
Is it burning any oil? Normally they will drop about 0.5L in 5000miles. Any more and you have a fault, valve stem seals or worn piston rings. This can lead to a blocked catalyst and reduced power.
