First time on this forum, but here goes... i've been having problems with my heaters when i first brought the car, the fan pushes out air, however the air is cold and does'nt really warm up. it will go from cold air to cool air, ut not hot/warm.
Anyway i've had all the old water and anti -freeze drained and new put in, still no joy. so i have changed the thermo-stat. Still no joy :(
Any Ideas??
Cheers
benz_123g
Discussion Starter · #3 · (Edited)
thanks for your reply mate.
The guy at the garage sadi that it warms the engine/pipes up however just doesnt warm up the inside
what is this heater matrix? and what causes it to damage?
Thanks again mate
The heater matrix is the part that brings the heat into the internal heating system. Its like a mini radiator, simular to the one under the bonnet. The matrix is located behind the heater panel, bit accessed from the drivers side, removal of some plastic panels is required.
All sorts can stop it working, main cause is age. Other things can be useing a leak stopper or simular
