1 - 7 of 7 Posts
Hi All,
I have a 2005 1.8 SRi Petrol 3D Vauxhal Corsa, bought used recently. I did the pedal test, for each code there are two possibilities just with different letters. How do I know what is actually the issue?
0568
P Cruise Control Set Signal
B Coolant temperature indicator circuit high
1555
P Electronic Variable Orifice Output
B LF/RF mirror control switch assembly circuit malfunction
2108
B RF/Passenger lumbar vertical sensor high
U Lost communications with ABS/TCS Control System
Thanks in advance!
Kai
Are there any lights on the dash. If not they will be old codes.
Yes, quite possible, the only light that came on while driving is the spanner in the car, but it didn't go into limp mode so I don't believe anything major is up. Next step will be to buy an Opcom to have a proper look at the codes and clear them.
In the other post on this forum some guy posted a whole list of codes - I understand the different letters (B, U, P etc) mean different areas of the car - is it possible to figure this out from the Pedal Test or does it require computer connection?
1 - 7 of 7 Posts
