1 - 20 of 37 Posts
Hi there chaps,
Does anyone have an idea as to what a Vauxhall dealer might charge for re-programming a Corsa C key so that it will work with my car? I can't find my spare :(
Cheers,
Dan :)
i seen it done
something like putting it in the car, turning to position one
pressing the lock key
after that i forgot . . . . . . . . .
its in the manual and you don't need to pay, you can do it yourself.
yer pretty much, or its in haynes or some expert will know. ive never looked into it but i KNOW you can do it without taking it to vaux.
Grumpy Old Git
mate p1ss easy, right put the key in ignition turn to position 1 or 2 cant remember that bit, then press lock then it should lock press unlock it should unlock then its coded to the car if in doubt fne vxl parts desk tell them you think your battery has gone cos you cant lock unlock your car but the light comes and tell them youve heard away to recode but cant remember it, thats how i found out
Just checked the car manual.
It reads:
synchronising remote control:
  • Switch on Ignition; system will then remain in synchronising mode for 30 seconds
  • Briefly press button (either open or close option) on the remote control unit while the unit is in the ignition.
  • The central locking system locks and unlocks to show that the remote control has been synchronised.
It reads:
Thats only synchronising a pre coded key back to the car!
Coding a new 1 in requires tech 2 as you need to programme in immobiliser codes etc!!
why not pull the chip out of the old key then put it into the new key then there is no need to get it reprogrammed. should work ok. pain in the ass that you can't code the vaux keys like the ford ones
1 - 20 of 37 Posts
