if the key you give yourself the same and you have already decided to make the change, melt it with a hot piece, as long as you do not give it to the remote control plate and the transponder that goes in a corner of the key against the sword, where you were nailing you are not misguided to unlock it, so kill it already with a piece of calie te iron and unlock it
I thought I could use a soldering iron but I don't have one and I don't want to damage the components is the any other way
any advice on how to take my old key apart and put it into the new case this is new key i bought
seperate the sliding section under your thumb ,see the vertical joint lines.a strong dragging action needed to slide it away from the metal blade,then split open the case. dont damage the printed circuit inside this must be transferred to your new case and key combo.
