1 - 10 of 10 Posts
Hi,
Hoping someone can give me some suggestions?
My interior light doesn't work on my 02 corsair comfort when the door is opened or even with the normal switch. The filaments in the bulbs seem to look okay and the fuse that correspondes to the interior light doesn't look like it blown either. I'm clueless and don't want to take it to someone for them to rip me off.
Any help would be appreciated (y)
Also is there anyone that is selling stock corsa alloys?
welcome to CCUK mate :wave:
how many bulbs have you got, is it just 1 bulb or 4 ?
have you checked the fuses ?
Give them a tap, mine had a loose fitting and came on some of the time, a knock would light one up so i took it appart to find the bulbs were a bit loose!
its got 4 bulbs and ive tried moving, tapping, hitting, jiggling and wobbling all of them but still nothing. The fuse in the actual fuse box under the bonet is ok... are there any other fuses i can check?
maybe it is just that the bulbs are all dead?
as you gor 4 bulbs, should be the same as mine, it will be 501 bulbs (sidelights)
have you checked to see if the wires have came off the back ?
looks like ill have to take a trip to halfords then. i presume i can get the 501 bulbs from there? ill check the wiring as well first.
thanks for the help jay!
1 - 10 of 10 Posts
