1 - 6 of 6 Posts
Irmscher mats - Do they fit in my C? *Solution*
Think i may just be having a dumb moment -
Tried to include pics to help find a solution.
Piece 1 - is the screw piece for the old mats that secures the mats down.
Piece 2 - a cover for the piece that is under the carpet.
Piece 3 - irmscher clip top piece
Piece 4 - the clip underneath the car carpet
Piece 5 - irmscher clip bottom piece
Looks to me like the carpet needs to come up and piece 5 to go underneath the carpet (instead of piece 4) to poke up for piece 3 that comes through the mats.
Confuzzled! :?
Discussion Starter · #6 · (Edited)
Had a little go tonight with success of the passenger side by doing the following -
  • Remove passenger door pocket (just clips)
  • Remove lower plastic door trim by unscrewing underneath passenger seat belt (t20 torx) and clips in the middle.
  • Also remove the 2nd plastic trim by the drivers footwell nut (10 spanner) underneath passenger footwell (cant remember size).
  • Also remove the left of the two screws of the glove box to enable this piece of trim to release (t20 again)
  • Then you will see the layer of carpet, underneath it is sound deading foamy stuff.
  • Start to peel the carpet away from the foam until you can reach your hand all the way to the clip nearest the centre console. (not nice if you have a hairy arm! ;) )
  • Swap the clips over for piece number 5 (see above pics). Repeat with the 2nd same clip.
  • Replace carpet and trim.
  • Enjoy clipping Irmscher mat down how it is suppose to! :D
1 - 6 of 6 Posts
