1 - 7 of 7 Posts
got my silver fascia and 2004> iso lead...plugged it all in perfect but gettin no power into the head unit?
any suggestions of what i could do from here?
please let me knw A.S.A.P
thanks
Is the lead originally a big sqare? if it is you have to run an ignition cable aswell, should be a yellow cable dangling loose!
ok, that means then the unit needs either a) a constant or b) an ignition.
You should have a yellow attached in the block, test this without your key in, if you get 12v then the red hanging off needs to be wired to an ignition, OR you can connect your trailing red wore to the yellow and just manually turn off the radio every time your done with it.
I thought orange (illumination) was to dim the display when you put your lights on at night?
1 - 7 of 7 Posts
