Hi all, has anyone got any ideas on what this problem could be? When I turn right, I get a clicking/knocking noise. It does not happen when dry steering, and doesn’t happen all the time too. Two weeks ago, I’ve had new both front droplinks, both cv boots, and both front brake pads.
Probably a cv joint. My passenger side one clunks but not all the time. I've got a new joint there to fit when I get a spare hour.
You usually find outer cv joints clunk more on full lock.
Theres nothing worse than having to do work twice, the new CV kit might have a new large band for the gaitor, I know my mechanic keeps universal types on the shelf.
The job itself is straightforward but becomes difficult if the balljoint nut or cv joint nut is damaged (there should be a new nut in the cv joint kit).
Hope this helps
Hi
Your car has a cv joint problem, go to your nearest mechanics they will help you, and you'll need to buy new ones and replace.
Administrator, Trusted Seller
cv joint had it on my old nova
