1 - 2 of 2 Posts
HI all,
My Corsa E 2015 is currently in the garage gettin repaired. I've been lucky to be given a 30 day old new Corsa which is absolutely amazing.
I have a query the new Corsa has really bright LED headlights (where as my 2015 Corsa only has LED lights around the trim of the headlights if that makes sense, and has halogen normal headlights and side beams).
Where do I go about looking at getting my headlights replaced to be the new LED ones like the new Corsa has? I presume its not as simple as just changing the bulb to LED.
Any help would be appreciated!
Cheers,
Alex
As the UK law stands you need to have LED head lamp units, the lamp unit must have been made in factory to take LED bulbs. Although you can buy LED bulbs for pretty much and light unit they are not all road legal anymore.
Try asking the main dealer if LED headlamps were an option on your car and if so start searching for a second hand pair. If the Corsa E is anything like older Vauxhalls then it will be pretty much a direct swap.
1 - 2 of 2 Posts
