i read somewhere that ka$h had taken his whole gearstick out,i had a look in my car and a poke around but couldnt see how it popped out could sum1 put up some pics on how to plz?
Lift the gaitor up, and you will see the stick fit through a metal ring on a shaft that leads to the gearbox.
Below this, there is a white plastic collar/base the the pivots in. This has two clips, one next to each footwell. Push these in and lift. The stick comes free of it's anchor point, now all you need to do is pop the white plastic collar off the ball joint on the bottom and lift it through the ring.
I'll getsome pics after 11 as I have to go out now :wink:
K
Right, sorry mate I lied, the clips are front and back, and I have arrowed the back one below:
Just unclip em (use a screwdriver or two, it's easier) and you'll have to force the ball out of the white flexible joint, then the stick just lifts out.
As long as the the white joint is in the chassis, there is nowhere for it to flex and allow the ball on the end of the stick to pop out
K
