301 - 320 of 338 Posts
Why not keep it 4 stud then using the 280mm Meriva fronts ?
Sent from my iPad using Tapatalk
Always that option, but it's a z20 let has been done with 5 stud on fronts and the rear has been left to 4 stud, I don't know which way to go tbh , I do like the calibra turbo wheels and then I like sri wheels so I'm unsure
Discussion Starter · #302 · (Edited)
Its taken months of research and money but I've finally done it!!
5 stud rear disc conversion, bolt on units no welding :D word can't explain how happy i am lol, pretty sure i'm the first to do this
Anyway so here it is, abs plugs match up the only things i need is discs and pads and a new handbrake cable but the hard works done :)
Can also see my HEL braided brake line there, need about half a meter of brake pipe and they will be connected up :)
Gave the carrier a coat of paint as well
Also got my steering wheel boss through so that got put in too
Fixed my injector problem swell but for some reason i don't have any pictures of that :\ but heres how the thing looks
Dont corsa d vxr rear hubs fit?
I know meriva didnt, mine had the mtech weld in plate with astra hubs
Hey mate, which solid flywheel did you use?
And I need some help dismounting the dual mass flywheel, is there a hint?
Thanks!
Discussion Starter · #316 ·
Thanks!
Didn't use a solid kept the duel mass
Impact gun onto the bolts or put a gearbox bolt back in and get a mate to hold the teeth with a pry bar
Sorry, again a stupid question, how did you pull the injectors out? Were they firmly fixed?
Was it necessary to drill the holes before refitting the injectors?
Thanks! :thumbsup:
Hey mate,
didn't you rip off the plastic fuel line at one injector?
Did you bought the whole part new at vauxhall/opel? It's a bit expensive for the quality... Or is there a way to order the 'L' shaped part seperatly?
At my Opel store only the whole part with all lines could be ordered.
And as I now know, the Bosch parts don't fit...
This is mine:
Thanks!
