321 - 338 of 338 Posts
Discussion Starter · #322 ·
Hey mate,
didn't you rip off the plastic fuel line at one injector?
Did you bought the whole part new at vauxhall/opel? It's a bit expensive for the quality... Or is there a way to order the 'L' shaped part seperatly?
At my Opel store only the whole part with all lines could be ordered.
And as I now know, the Bosch parts don't fit...
This is mine:
Thanks!
That is exactly what i done the first time, i had to buy the new part from vauxhall. Im not sure if you can just buy the 'L' pipe you'd have to check EPC :(
I learned to be a bit gentle with them after i broke mine
Good to see it with a bumper!
Looks mean :)
Discussion Starter · #323 ·
Got a bit of work done last night
Got my other disc hub on :)
Now the question is what rear brakes do i run, i now have the ability to run VXR 260mm or vivaro 265mm :D
Exhaust is all mounted and clamped in place
My mate is splitting his ZLET so i managed to get a few things off him
Whiteline rear arb being refurbished
Short shifter for the bottom of the gearstick, this needed some modifying but nothing major
Gearstick off
Short shifter on
Modifying base of gearstick
All bolted back up (forgot to measure the cable lengths, couldn't figure out why i couldn't move stick side to side :( )
Discussion Starter · #326 ·
More done this past week
Got these from venom motorsport
Just cheap fk streets as I'm not wanting spend a lot when the cars not running
Kept the adjusters in the rear and it sits quite nice with a bit of front rake
Got my seat frames back so that was all bolted down and the seat in position with harnesses bolted in
Couple of bits back on in the bay and this is where I'm at now
Sent from my iPad using Tapatalk
Discussion Starter · #329 ·
Couple more things done over the past month
Intercooler bolted up and most of the pipe work fitted
EGR cooling tube has been deleted so just had to blank the outlets
Whiteline rear roll bar fitted, can see the brake lines i had to make up
And lastly got a fire extinguisher so bolted that in
Got some brakes coming next week so should be another update soonish
just read all the way though from 1st page to here. Great thread very impressive, a lot of hard work went into this. Looking forward to see it finished.
Did you upgrade the fuel pump on it or just the injectors I'm thinking of upgrading the turbo on my combo c and want to know what sort of power the standard fuel pump and injectors will run
Heb je de lagerschalen overgezet in een vxr naaf? Astap is 27mm corsa c en 30mm corsa d ook de hoogte is anders 65 tegen 75mm. Lijkt mij niet waarschijnelijk dat er een pasklare naaf is in 5x110 in deze maten
