1161 - 1180 of 1211 Posts
Discussion Starter · #1,161 ·
Mr drew im in need of your expertise!! I’ve had an engine swap done on my zafira gsi and after it was done my car now won’t select anything other than 3rd which it’s stuck in!! The gearbox was fine before although the lever in the car was sloppy it worked I’ve taken the cables off and can manually move it back and forth but the knuckle to go up/Down won’t budge,do you know if anything could get damage other than the selector
It’s only nuts and bolts,don’t be afraid!!
Sorry, not really up on the later gearboxes, the last vauxhall one I had in bits was an F10 twenty plus years ago! I can't think of anything you can do on an engine swap that would cause the problem. Is it definitely your box? Might also be worth checking the oil level, I have seen a box that wouldn't come out of gear because it had been stood and the selectors were 'dry'
Amazing work as always.
Really makes me miss mine. Being completely serious, how much would it cost to get you to make me a rear bumper?
Have waited over a year now to try and find someone to sort mine so could finally finish fitting the bodykit, but no one is interested (bumper is **** fit and quality).
Once bumper and back end is sorted we may be able to get somewhere with the bodywork and get it closer to back on the road finally.
Discussion Starter · #1,163 ·
Hi Brad
Sorry to hear you're having more troubles. I could make you a fibre glass and kevlar bumper, It would be around £200, No idea how to ship it though! Also I cant guarantee that it would be a better fit that what you have now, I know mine isn't great around the hatch and has a 'twist' across the width of the car. Do you have any photos of how bad it is?
Will try getting the bodyshop to take some images Monday. I know it is quite thin and weak across most of bumper, and the mounts by the tailgate aren't that great.
Will have a word and if they think will be worth getting you to make one I will more than happily come and pick it up from you once completed.
Discussion Starter · #1,166 ·
Yes, he's up and running. I've replaced the 470cc injectors with 630cc ones as they were maxed and then started winding the boost up and making map adjustments to suit. Currently around 18psi with it tapering to 17psi at 7000RPM. I'll continue mapping till I get to 20psi but will likely run at a flat 18psi, which is all I can use in third gear without the traction control switched on, performance is pretty brisk as it is with 40mph to 70mph taking 2.4 seconds. The only other work i've done is replace the oil suction pipe on the gearbox which was leaking and fit a gearbox oil temperature sensor.
Discussion Starter · #1,168 ·
The car is fitted with a xap x-dash. It allows you to program various screen layouts and setup warnings and has shift lights built in.
Discussion Starter · #1,169 ·
Not much of an update as I haven't been able to do any proper work on the car for three months, mostly because of continuously poor weather, but I did take it out for a little mapping session the other day and tested the launch control on a slightly damp road, all went well until the launch control switched off and then it just spun the wheels.
Discussion Starter · #1,173 ·
I don't know if bogged is the right description, I'd guesstimated the settings and set the launch rpm at 2.5k,First gear is tall, 55mph at 7200rpm so 2.5k is 20mph roadspeed. This gives you two choices. Dump the clutch and spin the wheels until roadspeed is 20mph then let the launch algorithm control the wheel slip after that OR let the clutch out progressively (as progressive as you can be with a metallic paddle clutch) allow the revs to drop slightly and walk the car off the line allowing the ECU to stop the wheels slipping in the first place, which is what I did. Data logging will allow me to figure out which is best, hopefully. If you listen to the sound , carefully, you hear the revs drop as the clutch is let out,then build under launch control then suddenly increase when launch turns off, the recirc goes off as I peddle it to try and kill the wheelspin, the tyres spin again so I lift , the recirc goes off and i select 2nd gear, more wheelspin so I lift and select 3rd, accelerate ,then lift, select 4th and apply the brakes before the ninety right at the end of the lane!
Discussion Starter · #1,174 ·
Another small update, In an attempt to get a wider range of boost control I've decided to ditch the regular BCS and actuator setup for a garrett electro-mechanical actuator usually found on VNT diesel turbos. One of the ideas been that I can force the waste gate open when launching and stop the engine effectively going into anti lag and building boost.
First task was to source an actuator that's PWM controlled and not can bus, turns out a 6nw008412 will do.
So remove the standard parts.
Then make a bracket the mounts the new actuator on the stock mount.
Fit a 2 pin plug on the actuator and earth it locally to the bracket and a ball joint on the actuator arm, this and the above bracket means I can easily swap straight back to 'normal' if I have to
Actuator mounted and aligned with wastegate arm
And a small, extremely dull, video of the wastegate under control of the ECU. Apologies for the quality but its not easy trying operate the camera whilst not burning you arm or melting the camera and changing the ecu map settings on the laptop..
All I need now is for lock down to ease so I can go out and map it, Knowing my luck id' get pulled by the police and I Don't think they will believe its 'neccessary travel'!
Makes a lot of sense, all you can do is data log and test, and make tweaks! Sorry for the delayed reply...
Discussion Starter · #1,176 ·
Have done a little more tweaking, revs dropping a bit more than I like but getting there.. 0.5 bar boost in first gear completely eliminates wheel spin, currently 0.8 bar in second but will take a little more , 0-60 in 5secs, 0-80 in 7secs. Not bad for a fwd tin top.
Discussion Starter · #1,179 ·
When I placed the order I was told twenty weeks, every time I chased it i was told there's a delay but couldn't get an actual explanation of what the delay was, Which was the most frustrating part, if they had been upfront and said it would take forever I'd have been ok with it.
Don't remind me. I used to be the QC Manager (chemicals) and the sales people were always saying it was "in QC" when I knew we hadn't even received/made it yet. Instead of being upfront and letting the customer choose to get on with something else, they sat around for days unable to make stuff.
Apols for my losing track of all your work (and also my curiosity not matched by decent understanding) but is this to get more hp at higher revs or to better match replacement piston upgrades?
