Finally an update. Literally the day after my last update I went down with the covid which knocked me out for two weeks, then work crap and christmas means I havent done much, however the last few weekends I got back on it..
The rear undertray I've been using was an off the shelf item that was thick fibreglass and didnt really fit and I have to run a large aluminium tray to reach from the suspension beam to the undertray which made suspension checks and adjustments a pain, so, off with the tray and out with the power tools.
added an extension to the front, the 'skid plates' give it some shape and will have foam embedded in them to increase stifness of the finished tray, also added two ' diffuser tunnels' at the sides which will do nothing but will look trick.
Adding lots of filler to get the radiuses in the corners etc
and the first coat of primer applied.
It will probably need another four coats before I can start flatting it to the final finish.
