Hi,
1.4 was running fine, letting some water onto floor when I finally passed it on to newly licensed daughter.
I tell her to use tarp to keep water out when possible, ignoring that she/they take it to mechanic for brake fluid,, new battery etc.
Before long it's losing power and I'm called in.
Pedal test reveals numerous codes, I do get it started eventually and rashly head off down the road at weak pace, but at the first corner it really loses it, and subsequent restarts peter out, until I have to push it 400 yards home.
P1612 Serial Communication with Device 12 (IPM, Instrument Panel Module
P1614 Serial Communication with Device 14 (RIM, Radio Interface Module)
P1615 Serial Communication with Device 15 (VTD, Vehicle Theft Deterrent)
P1616 is Wrong Vehicle ID from Instrument Control Module C-40 /
U2107 Lost communications with Body Control System
are most of the codes encountered.
To complicate matters a while back I'd decided to share one transponder chip between two key blades by gluing it behind plastic ignition cover. It worked. BUT now when I look I can't find any trace of it. An auto locksmith is summoned who takes pity on me and supplies two new chips for the keys for only 35 quid... BECAUSE the car still won't start.
My question is, With so many codes still evident does this indicate a loose connector rather than the FAULTS as indicated i.e. spurious faults. ???
My plan is to thoroughly dry out dash etc, and pull out clocks, before allowing the calling of "experts"... whose instinct may be to replace parts as indicated. And may approach mechanic to see if my note in handbook re key chip caused a response.
Another question : Does the (BCM) deny starting by cutting power to the spark plugs ?
Thanks for any help,
from err, Australia
from err, Australia
