1 - 6 of 6 Posts
Hi came to start car today battery is fully charged switched on ignition only ignition light and engine management light on started ran for 2seconds think fuel pump no electric then no lights at all everything dead no click from starter nothing
Could it be earth strap or main cable fro battery ?
Help
Best regards Gary
Corsa C 2004 z10xep
If no joy check the 30 amp fuse in engine bay. These also another fuse think it’s a 20amp. Check they have voltage with a meter. Other fuse if no volts is in the hidden fuse box under the windscreen has a fuse in there for the immobiliser buts it’s hard to get to. But check battery and earths and engine is earthed.
Thanks I'll let you know how I get on the cars been stode a while it in front of my lockup just move it back to get in its fired first time for last 2,years poor thing 👍
Hi thanks for all the help it was the multi connector on the back of the bulkhead next to the screen washer it looked like it had got wet wiped and WD 40 and ignition and all dash lights on started first time
1 - 6 of 6 Posts
