Hi.
This morning, I took off a trailer from my towbar, while the hazard lights were flashing. However, I accidently pulled the trailer's wires off the trailer plug (easy fix), but now, neither the turn signal lights or the hazards lights flash at all. All I get is the the quick flashing and clicking on the dashboard. I suspect I have shorted out a fuse or relay, but I am unsure which. Again, absolutely no flashing, so would that be a fuse? If yes, where is it located?
Kind regards.
Probably the indicator relay. That's situated in the BCM which is the black box next to the battery. The relay is at the front of the BCM - it's big and yellow!
(this info is based on how it's laid out in my corsa c, so may be different in yours)
Thanks for your reply! I have located the indicator relay, which in my case (2006 Z12XEP) are two smaller yellow relays, one for each side. They both click according to which side I turn the flashers on. I have also tried switching them around, but without any results.
Does the clicking mean they are still functional or should they be replaced?
Honestly I don't really know!
My indicators went kaput a few days ago - fast flashing and clicking inside the car on the dash, but no lights outside.
Mine was the relay. Cost £27.
