1 - 20 of 28 Posts
Hi everyone,
Im after changing the leds in the rear number plate, I'v searched on here and they all say you just pull it out and swap the bulb.
However, I'v took mine out and im left with this;
How do i get inside to put new led in?
Cheers
Thats all there is mate, I'v had a look, Any ideas?
I'll take a picture of mine tomoz mate and show you.
but there should be like.... hard to explain but like a plug in the hole the other side of the clip that holds the bulb
you un plug the holder from the plug and then you remove the led/bulb from the other bit :|
So is the holder still connected to the car then pal?
ok mate, Nice one
You would have had to twist and pull out the wire/bulb to take a picture of the holder above....if the holder just popped out on its own then the wire must be inside the bumper and youve had no number plate lights on at all...
Oh right well i just got a flat head and popped it out, didnt have to untwist anything, So its in the bumper somewhere?
Any ideas how to find it?
Just feel around inside the gap in the bumper where the holder came out of, theres only one wire there with the 501 bulb on the end..
Discussion Starter · #11 ·
Just been and had a quick look/feel and theres nothing except the wiring loom that connects into the back of that.......... Is the led holder connected to the loom or is it seperate from that?
Discussion Starter · #12 ·
I cant even test to see if i can see any light either, because my headlight switch is fooked so i dont have one in atm, and theres no other way to check is there if i cant turn my headlights on?
Discussion Starter · #13 ·
bump
Discussion Starter · #14 ·
bump
Liking the numberplate :yes:
Discussion Starter · #18 ·
So basically the part of the picture that i posted where the wiring loom goes in, Pulls out to reveal the led? if that makes sense lol
lift up the white harness block to take the light and holder off the car
then twist and pull the grey bit to take the bulb out
Well...
Iv just got some 4 led things, they're ok...
but do to the bulb holders been crap (they both face the sme way if that makes sence)
1 side of the plate is lit "better" than the other side
anyway
@barnesy
Yes, on my picture, the part with the bulb in, twists out of the holder, that's about you get at it to change it :)
I'll get some photos when it goes dark for you
1 - 20 of 28 Posts
