For you mechanics out there, i have just replaced one of my oil breather pipes due to them cracking and with the help of a cat which some of you may of seen a few days back.
anyway i cannot see a clip on the breather pipe which goes further down to the back of the engine and have no idea how to get it off, the top of the pipe is easy to get off just the concern of the bottom part. it is the thinner one on the left as you look at the engine, i have put in the put in piccy, pipe that needs doing is the badly cracked one in the photo
if you mean the pipe that is the smaller one on the rocker cover that goes behid the inlet manifold then its just a push slide on fit, becarful pulling it off that u dont snap the plastic pipe it goes onto but yeah just a slide on.
took mine off loads a times now to clear it out :)
