Hi all, when removing my coil pack today to replace the spark plugs in my 1.0 12v I noticed a certain amount of oil in the spark plug well on one side. Any ideas what this could be?? Also part of the coil pack appears broken on the rubber end. Some pictures attached, thanks
36313
36314
36315
According to the manual, it is not necessary to give it gasket paste, but it does not hurt if you want to give it a little, like a thread or so, not the whole boat, as standard they use the VICTOR REINZ brand, and to change the gasket tighten the screws in X from the inside out, the work is not complicated once you see the meeting, dare to do it at home, it does not have more work than 20 minutes
