1 - 3 of 3 Posts
Greetings everyone im from South Africa i have a 2007 Opel Corsa Utility Club 1.8 (Bakkie) im suspecting that it has elecrrical issues i dnt have any mechanical background, the car dims when i press the brakes or turn the steering wheel, and when i depressed the brakes the revs go up,(i just changed the idle air control valve bt it didnt help) the aircon has been dead for a while i jus need the some sort of diagram for the relays nd fuses with the appropriate voltages(amps) and il welcome any advice or suggestions. Thank you
Corsa C 2004 z10xep
By what you are saying it could be a bad earth and when you have a good amount of usage the power is dropping. Dimming lights etc. It could also be a bad connection from alternator. Check the battery terminals and follow the ground wires to shell there are a few of them. And check the 2 grounds on the engine one at ecu and other is on one of the engine to gearbox housing. Bolt Round the back. Check these and let us know.
Unfortunately for you the ute's or Bakkies are wired completely different to the UK spec'd models on the Corsa C platform. so finding any wiring diagrams or even fuse lay outs is going to be hard. A friend in the UK has managed to find one that was imported from SA and he has now fitted the z22se engine and supercharger. This was quite a task as nobody could find wiring diagrams for the ute and nobody in SA even Opel dealers would help.
It does sound like you may have 2 faults, 1 an air leak on the brake servo line somewhere, try spraying brake cleaner along the vacuum pipes and listen for engine rpm to increase to find the leak. 2 the alternator or main power wires to the engine could be in poor condition, check the wiring and connections and for 13.2V + at the battery with engine running.
1 - 3 of 3 Posts
