Hello Mike. 1999 is a Corsa B, not a Corsa C, but you might still get help here. P000 doesn't mean anything, are you sure it read correctly? Normally, there are four digits. P0000 means no fault codes detected, as far as I know.
Have another look and it helps if you could comment on what you used to get the code and what symptoms your car has developed.
That is not a fault code. It means that no fault codes were detected. What do you mean by branches get red hot?
