1 - 3 of 3 Posts
Good day,
I am at my hairs-end, I have an Opel Corsa C(VITA) C, 1.4 Engine: Z14XE-ZOU37619 & Chassis : WOLOXC-F6814228318. It cranks then a few seconds later goes off. It had been packed for close to a year.
Done :
1. Oil changed
2. Water suspected got into the tank - it has since been drained and cleaned twice.
3. Spark plugs changed.
4. Starter motor changed
5. Got a diagnosis changed but the technician cleared the errors and no new errors are showing up since the clearance.
6. Fuel system checked and fuel reaching the engine.
7. Spark plugs are firing.
What can be causing it to switch off immediatley after it cranks on?
Regards
and when does it turn on? can you speed up? does the needle chart answer? goes to 3 pistons?
I dies almost immediately after switching on. I have further found out that the car is seeping fuel from the fuel filter located under or near fuel tank.
1 - 3 of 3 Posts
