Hello everyone,
I've got P0170 code on my Corsa C 1.8L from 2005.
A few symptomes I notice are:
Recently i've done the following things:
I've checked:
I've scanned the car and the pictures down below show the data from the freeze frame, but I don't know how to interpret the data correctly. If needed, I can also share the live-data.
I don't know where to go on from here to solve this code, so all the help would be much appreciated! Thanks!
- When I start the car the revs go up like crazy for a moment, and then when I press the throttle the rpm's go up but when lifting the clutch the car drops dead completely for a few seconds before being able to start driving. During this period of time I can press the throttle as hard as I want, but nothing happens.
- The car drives fine, but once the code is cleared, it only returns when driving at high speed.
- Sometimes when going full throttle, the car seems a bit hesitant and holding back.
- Sometimes whilst waiting at a red light at idle, the rpm's are fluctuating by themselves having a little party.
- There might be a slight power loss.
- Changed oil & filter
- Changed fuel filter
- Changed throttle body
I've checked:
- PCV vavle: couldn't blow through it
- Vacuum hoses: no leaks as far as I can tell
