1 - 9 of 9 Posts
Hi guys I have noticed some drops in power after I lift off and then re-apply the throttle. I have just done the pedal test and it threw up this code 16161612! Has anyone gt any ideas what this relates to? Cheers
yea that would make sense, but immobiliser, and vehicle id, sunds like my car s stoled, can ths be due to my battery being disconnected all night??
disconnect the battery for about half an hour to a hour or replace the problems
i also would like to know what the "P1616 Wrong Vehicle ID from Instrument Control Module C-40" fault code means as i am reading this too!
I am also receiving these codes. Does it mean an aftermarket speedo has been fitted or does it mean the battery has disconnected and reset coding to key. Or could it mean an another key has been used with the vehicle?.
Any help would be cooool
Cheers
P1616 Wrong Vehicle ID from Instrument Control Module C-40..
That's if you've put a new set of dials in from a different corsa, and not redone the ECU. Surely you're car wouldn't start if you had this code?
P1616 can happen if the connector on the back of the instrument panel goes dodgy. It's a common fault.
1 - 9 of 9 Posts
