So I have done the pedal test to see if my 09 combo van has any fault codes. All the videos I have seen show the car with the spanner flashing, however I get the emission light flashing. Is this the same thing?
Is it a diesel? Does the spanner light come on with contact on? If the emission light flashes, are there any fault codes and are they making any sense if you google them?
It's a diesel, 1.3.
Yes the spanner/ car light comes on, then turns off.
At first it threw up a weird code 14, 1, 0, 8. This is odd that it flashed 14 times first set of flashes.
Just after this the Speedo stopped working and now it gives me 1612.
Speedo has started again, so I think it's a loose connection. That said it could possibly be an abs fault due to brake judder I'm getting and I'm not convinced the discs are warped. Abs rings look ok, so it could be the cable, which is linked to the Speedo?
