Hi everyone
I have an issue with my 2006 1.2 petrol with 65000 miles.
The issue seems to happen at random intervals and goes as follows:
I try to start the engine but it makes that cranking sound and doesn't start. So I stop and try again. This time it will start but barely. The service light will stay on. When I drive after starting it like this, it takes a lot of revs to get up to speed. It seems like it doesn't want to move.
If instead of driving off, I turn the engine off and then try to start again, it will start normally and will drive normally too without issue. The service light will stay on for 1 or 2 seconds longer than usual but will then turn off.
I can't pinpoint exactly when it will happen as it has happened when the engine is cold or hot. And it has been consistent with the way I've described above. It seems like a complete gamble because it will sometimes start first time without any issues. This problem has only started happening from last week and has only happened about 10 times since then with daily driving.
I had a full service done on it in November and have only driven about 1500 miles since then.
Any help is appreciated
