1 - 2 of 2 Posts
I have a corsa 1.3 tdci, it starts first time in the mornings but if I turn the car off before the heaters are warm it won’t start again , I try and start it and it won’t start yet if I leave it for around 20 minutes and try starting it again it starts , I’ve had the egr value done , put a new battery on it , I’ve had the crank sensor tested and none of these are the problem, do anyone know what could cause this please
Corsa C 2004 z10xep
Have you checked fuel pump. If it’s priming. Could also be the relays for the pump or the injectors. Swap them over see if it makes a difference. Or tap them with ignition on and try stating engine if works then will be a relay and just need to find out witch one.
1 - 2 of 2 Posts
