1 - 3 of 3 Posts
I've been battling my Holden Barina (Corsa C) for the last couple of years and eventually gave up on it and left it in the barn. I now need the space back so I'm having another crack at getting it going again.
I finally got a working OP-COM cable and software and the errors I've got are the common P1615, P1616, U2107 etc. Reading the forums it looks like extended periods with a flat battery could mean the BCM needs resetting.
Before I go ahead and break something, would someone have the steps to reprogram it?
Cheers
Don’t reset anything!
Make a list, what faultcode is in every module, per module. Post here before you touch any other button in opcom.
Discussion Starter #3 (Edited)
Here's the list of error codes I'm getting in the Engine module - shall we play error code bingo? ;-) :
P1615 - Wrong Vehicle ID from Body Control Module
(00) - Present
P1616 - Wrong Vehicle ID from Instrument Control Module
(00) - Present
U2107 - CAN-Bus no Communication with Body Control Module
(00) - Present
P1483 - Fan Relay 3 Signal Low / Open Circuit
(04) - Present
P0230 - Fuel Pump Relay Voltage Low
(04) - Present
P1230 - Main Relay Stuck Closed
(0B) - Present
P1230 - Main Relay Stuck Open
(0A) - Not present
P1612 - Immobiliser No Or Wrong Signal
(00) - Not present
P1613 - Immobiliser No Or Wrong Signal
(00) - Not present
P0650 - Malfunction Indicator Lamp Voltage Low
(02) - Not present
P0230 - Fuel Pump Relay Contact Problem
(00) - Not present
P0460 - Tank Level Sensor Circuit High Input
(01) - Not present
1 - 3 of 3 Posts
