well its been a while as I couldn't get photo's up but sorted that at last.
scrapped the corsa B due to rust, got a 2nd corsa C to use while Ruby is off the road doing engine upgrade and other work.
new bottom end is built, saab b207r block, z22se crank lightend and balanced, balancer shafts removed, eagle rods, wiesco pistons with 9:1 cr, comp cam blower cams and 2.8" charger pulley. also found room to fit an air to oil cooler. running sweet and booked for remap at Courtenay sport soon.
also fitted irmscher front splitter, supercharger badge, quaffie diff in a hybrid corsa 1.7 f23 gearbox with 3.55:1 final drive (this car is for every day use and 70mph is now 2500rpm!), lighter flywheel, sachs clutch, and tided up ecu to body wiring which has ment fitting a standard corsa throttle pedal with a vx220 map. still lots more to do, new sound system, new exhaust system, interior work.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
and the new project car, 05 z12xep sxi
[/IMG]
will start a new thread for the new car.
