Ive got a bit of a head wrecker with my corsa c at the minute. The passenger side rear drums getting hot after say 20 miles on the motorway with no or little brakes being used. Ive jacked it up and the wheel spins fine and doesnt seem to be dragging.
Its had new drums, shoes, bearings, handbrake cables, cable guides.
Ive stripped them down and nothings sticking that i can see The handbrake lever is returning on the shoes to the stop every time its operated with the drum off. Ive evened backed the adjuster off inside the drum half a turn but its still getting excessively hot.
If i jack the car up and use the handbrake or footbrake then release it, both rear wheels spin freely so dont think its holding on.
Am i missing something obvious here.
Im thing of removing both rear drums and resetting the adjusters back, loosen handbrake right off and then refit the drums and let the auto adjusters do their thing.
Anyone know if the auto adjuster works when you brake while moving in reverse/forward or is it done by the hand brake lever.
