I accidently dropped a metal object into the cigarette lighter which caused a spark and now the reverse lights do not work. I presume the 20A fuse has blown which I found out to be number 26.
However I looked at the fuse diagram in the manual and compared it to the fusebox and number 26 is empty but there are three 20A fuses above it.
Hi, I have a Corsa 1.3 cdti on a 54 plate.
When I put the key into the ignition barrel it doesn't turn, I've tried wiggling the steering wheel, forcing the key, WD40, gently moving the key in and out of the barrel whilst turning but nothing has worked. The key still works in the door lock just...
Hey Guys,
I bought some Carlube 10W/40 semi-synthetic A3/B4 oil for my car yesterday. Normally if I buy it at the shop I don't take notice of that A3/B3/B4 rating.
However, I decided to look it up and turns out that B4 is spec'd for high performance cars and B3 is for older cars?
So my...
I wasn't sure if there was a thread already for this kinda thing, search showed nothing, so I figured I'd start one. I have no pics unfortunately but I'll give a back story and add on what I also did to it in december
I wanted a cheap A2B/commute to work runaround to reduce the mileage off my...
Hava Corsa c 1.4 and a Combo 1.4 and the water boils in the radiator then overflows. Had both head machined however Im wondering if the water channels in the cylinder head are all blocked up. Both have had new water pumps and thermostats fitted and the fan kicks in at the required 91 degrees...
Hi all,
As above really, I've got a Corsa SXi wheel in my combo but it's boring, and everybody's got them.
Does anybody know what'll fit, Corsa D/E, Adam etc....
Even aftermarket, who's got what fitted?
Thanks
