HI, Im fitting the Sony head unit today, ive had a read of the instructions and i aparently have to connect a wire to the parking break, as i understand this is to dissable the 'video in' when the car is moving....ie, i can only use this when the car is parked with the hanbrake applied......Ive had a thought, if i connect this wire to a switched live, like the cigarette lighter of something, i should be able to use 'video in' whilst driving (should i want to)....what do you think? Will this work, or would you just wire it as per instructions?
Thanks lads......
Wire it the easiest way. Legally you should follow the book as you aint allowed to use it when moving, but I know a few footballers purposely have that feature wired out so that they can be used while driving!
It's up to you, you won't really want it on when moving, but your passengers might, so to a switched live it is :D
