1 - 7 of 7 Posts
Hi,
Today a squeaking noise has appeared from the front brakes , when driving at any speed , whether the brake pedal is pressed or not , it gets louder / more consistent when the pedal is pressed, could this be a sign of new discs / pads or both?
New pads needed. There is a metal clip that makes that noise when the pad wears down enough.
Recomended to change the pads and disks at the same time for the best braking effectivness
Get your pads changed soon i reckon as you could fudge up your disks too if you run your pads too low,
1 - 7 of 7 Posts
