1 - 20 of 25 Posts
probably need a new set of bolts mate and maybe another plate for the bottom set off bolts to go into inside the mirror (mean the bit that is bending out at the bottom)dont actually know what its called lol.should be able to get them fairly cheap from vx i would of thought.be best to take the mirror off completely from inside and check everything is ok in there as well
lol - its suppsed to do that so you dont smash it to a million bits....
line up the metal lugs to the holes and push really fecking hard! lol
hes just knocked it off hasnt her?
Discussion Starter · #6 · (Edited)
Administrator, Trusted Seller
there ment to do that
best to take the baseplate off to try & get to snap it back into place
ether that or push very very hard
you old man about? seriuosly, you just need to get abit of weight behind it and push bloody hard,
id pop the one back off and line em up and have another go.
Discussion Starter · #13 ·
Tried that, still can't get the bugger back on! :banghead:
Ahh unlucky man, hope it gets fixed.
Bad day for me too, just found out I STILL can't have my car back yet! :banghead:
Discussion Starter · #16 ·
It'll get fixed, don't worry.
If only anger = strength like with the Hulk, then I'd have no problem. :lol:
can you not pop down with your car after i finish work mate?
its piece of cakey to do
wait till your old man gets home mate and get him to have a go - really dont understand why ytou cant get it back on - should go on as easy as you got it off....
had mine knocked off by a mini, had to take the base plate off, file the pins down a tiny amount, grease them up, then me & my old man push them in,
1 - 20 of 25 Posts
