Afternoon everyone.
I am trying to set up my car for better handling for sprints, track days etc. I am running a 1.2i Twinport on Exclusiv 16" wheels with Conti SportContact 3's. Can anyone recommend what camber/caster angles provide better turn-in, or am I better off sticking with Vauxhall standard settings? I use the car as a daily driver too.
Cheers
Camber and castor (which is a non trivial thing to adjust on the corsa) wont make a difference to turn in. You'll want to adjust toe, to put some slip in the tires, but this can cause instability in a straight line if taken too far. Adjusting ride height at one end of the car will change the way the weight transfers at turn in which may also help.
