My steering wheel has some play in it,I can pull and push it with about 15 mm play,can anybody give me some advice on best solution thanks
Assuming the bolts that secures the wheel to the column and column to the chassis is tight then the column is faulty, not much you can do expect replace the column.
Thanks. Would the car go through a mot
Discussion Starter #4
Thanks would the car pass mot
