You need an amp aswellchazsxi said:can you just put a sub into the speaker wires then?! :S or do u need an amp aswell? do u use the rear speaker wires?!
chazsxi said:do you need to get a wiring kit to install it into the normal speaker wires or just some standard speaker wire?
yes,chazsxi said:guessing u still have to run a power cable for the amp to the battery?
...NO!!!!!!chazsxi said:guessing u still have to run a power cable for the amp to the battery?
Epic bump is epic.this thread is 7 years old wtf
