1 - 7 of 7 Posts
i just bought an sxi knob yesterday and the fooker dont fit on my lift up reverse,has the sxi got a different stick?
i know that but is it a different size cos the hole for the lift up reverse is too small and ive spent all mornin sanding the inside of it to try and make it fit
The stick is a different size mate, it's also shorter!
cheers kash ive just spent half the day sanding the **** out of the inside so it'll fit,du think its worth buyin the stick tho?is it much £
Swopped the stick out, 10 min job at most. You just lift off the gaitor and unclip the white base at the front and back. I posted a pic on here a couple of weeks ago showing the clip. You then put out teh ball joint and remove the old stick. Put in the new one, pop it back in to the ball joint and then clip into place. Job done. I got me handbrake and gearstick of Ebay for £25 about 3 month ago. Nice simple mod, and not too costly
1 - 7 of 7 Posts
