1 - 3 of 3 Posts
Hi, my corsa C throttle is playing up, it idles around 1k - 1.5k rpm and when I press the throttle all the way to the floor it refuses to rev above 2.5k, the car does require a rear oxygen sensor however it was revving completely fine until a couple of days ago, any Ideas?
Corsa C 2004 z10xep
Engine in limp mode. Would need to read codes. As say oxygen sensor needs replaced. It might of been occasionally working but now not. Flooded or choked up the sensor would put engine in limp mode.
You need to get it plugged in to a diagnostic tool to see what's going on and read/clear any fault codes. You can also do "the pedal test" Google Corsa C pedal test videos.
1 - 3 of 3 Posts
