Just wondering if anyone has installed undercar neons themselves?? I just picked up a cheap cheap set of led neons off ebay,with no instructions!! Anyone done it them selves? basically,how do u wire them up? Does each neon need to be fused? do i wire the whole set upto the battery or an existing connection(such as fogs) e.t.c.??? :? :? i was thinkin wire upto fogs power supply (as this one should already be fused?) and put my own switch somewhere,so neons will come on when fogs are on,or when i choose to switch them on?
easy
mine are held onto the brake pipes and fuel pipes (different sides of the car) and the front and rear ones are held onto what ever they would clip onto. had to drill a hole in my bulkhead to get the wiring for the switch into the interior but if u have the same type of LED neons as me this is a must as big control box can only be operated this way 2 go through all the neon modes. hope that helps
