1 - 20 of 182 Posts
Right my dads garage has 8 vauxhalls all suffereing from ****ed O2 sensors due to supermarket fuel, i rang people i know at all my local vauxhall dealers and one has 15 and one has 11 cars all with the same problem.
They are 90% sure that its tescos fuel that has caused this problem, its only started over the last week or so
i put £20 of tesco fuel in last night, done 100 miles and im ok:)
that was super unleaded
i never use tesco petrol anyway dont get as many miles from it. its cheapo for a reason! good bit of info tho mate cheers! :salute:
cheers for the advice, nothing but shell optimax in my 1.0L ;)
I always fill up at tesco, regular and super when I'm feeling flush.
I collect clubcard points!
i work at tesco so i have never filled up anywhere else. oh dear does that explain as to why my emmision lights come on today???
btw whats an 02 sensor do?
Discussion Starter #8 (Edited)
not sure i will find out what the signs are, not sure what the O2 sensor actually does
oooo dear - coincidence?! :\
i filled up on wednesday too. my cars been a bugger to start when warm see my thread in the mechanical section.
Discussion Starter #12
keep topping up with quarter of a tank of shell or something till you have used all the old fuel, they are having to drain the tanks and re fill the cars
02/lambda sensor measures oxygen present in exhaust emissions and then fueling is adjusted based on this. Car will probably run rich/lean with a fooked one. The Engine emissions light should show if it's fadged.
As far as I thought, all regular fuels, be it Tesco, Shell etc come from the same place and are exactly the same........I'm sure Marc once said that anyway.
Cheers for the info, I'll go morrisons for petrol tomorrow instead :)
it would explain it, it sound likes it coughing when it first starts up, where is this sensor?
first my car with a spanner light came on and stayed on then when i started it last time i hade the emisions light come on.
Discussion Starter #18
na supermarket fuels have a lot lower lvl of something (cant remember the chemical!!) octane springs to mind :dontknow:
I read somthing about tescos fuel in fast car I think, this was about a year ago!
there "super" or "ultimate" fuel has somthinglike 95% octane in it!(somwhere along thoes lines) the normal has somthing like 90% or 85%, maybe these levels of Octane have somthing to do with it!?
that would explain my lights then
1 - 20 of 182 Posts
