1 - 3 of 3 Posts
Vauxhall Servicing
For any make or model, from replacing bulbs to head gaskets, We can do it all!
Work will be carried out, by a fully qualified Vauxhall mechanic (for 5+ years)
All parts used are GM Vauxhall parts (unless requested otherwise)
A basic service consists of the following
Visual - lights checked, All under bonnet levels checked (and corrected if need be) Horn, wipers and washers checked, brakes checked (maybe addition charge if drum are required to be inspected) steering and suspension components checked, underside of car checked with finally a tyre condition check inc pressured corrected
Small service, £69.99:
All of the above,
Intermediate service, £89.99
All of the above, plus oil and filter changed, plus pollen filter and key remote battery
Major service, £149.99
All of the above, plus oil and filter changed, plus pollen filter, key battery, fuel filter, air filter and spark plugs (if applicable)
Additional Items (Inc Fluids)
Brake fluid change £15
Antifreeze change £20
Drum brakes removed, cleaned and adjusted £25
Note: Oil used is correct grade for car, all Z code engine from 04 onwards should run 5w30 Grade, and this is what is used
Vauxhall Diagnostics/Tech 2 Programming
5 years experience working on Vauxhall, you can be trusted the experience will pay off, anyone can read off codes, but if it doesn’t tell them the exact fault - do they know what to do?
We have Vauxhalls TIS200 program to run the correct diag route to your fault, along with all the wiring diagrams and service information. Using the Diag tester, we can read your trouble codes stored by you ECU, we can check the data list of your vehicle to see whats happening, aswell as actutorating sensors to test them.
Initial Diag - Upto Hour and a Half £45
If the fault is not found within the Time, then there will be an additional charge, as it will most likely be not an obvious fault and require further investigation, 9/10 times if will be found or have a very good idea of the problem within the time.
Code Reading/Clearing £10
If for what ever reason, you just want the codes read to you with no diag, or if you wish just to have fault codes cleared (no advise will be given)
Programming
Programming Cruise control £20 (supply and fitting is also available)
Programming/resetting ECU's £20
Changing Personal settings £10 (Astra H)
Mileage Correction £30 (Corsa B, Corsa C, Meriva, Tigra B, Astra G, Zafira)
Programming Keys £20
Do to legal reasons, you should only adjust mileage if your clocks have been changed and require the mileage corrected or if you are informing the new owner
Tuning/Conversions
Almost anything can be done, but there’s always a cost, whether you want an engine conversion, or some lowering springs done. Or if you just want advice on medications we can advise you in the right direction. Most items will require an arranged price, but always a professional job.
*PLEASE SEE OTHER THREAD FOR REMAPPING*
Corsa C Lowering Springs Only £50
Corsa C Shocks + Springs £60
Corsa C Coilover inc Ride height adjustment £75
Front Pads Changed £25
Front Discs + Pads £35
Rear Pads £25
Rear Discs + Pads £35
Head light change £25
HID Fitment £30
Clutch/Gearbox Any Corsa £150
Poly Bush Front & Rear £70
Performance Inlet manifold £90 inc extending wiring loom
Camshafts Change £80
Exhaust manifold change £45
Backbox change £25
Middle box and back box change £40
Engine Change (like for like) £190
Steering Rack Change £165 inc parts
Gearlinkage Change £65 inc parts
Quiafe ATB £180 Labour only
Timing Chain replacement £250 inc parts
Headgasket replacement £250-£300 dependent on engine
2.0 Turbo Conversion £595 Labour only
1.8 Conversion £395 Labour only
1.4 Conversion £295 Labour only
1.2/1.4/1.8 Turbo Conversion £enquire
An Idea of what can be done
VXR turbo upgrade
Manifolds/Exhausts
Uprated Brakes
Dump Valve fitment
Boost Gauge fitment
Quaiffe Diff fitment
Turbo Conversions
FMIC fitment
Camshafts changed
Anything not listed Enquire for quote
Located SOUTH EAST, KENT post code ME12, Isle of Sheppey
My Contact Details
Email – [email protected]
Or PM me on here
Facebook Page
http://www.facebook.com/pages/WG-Mot...07028252672432
1 - 3 of 3 Posts
