1 - 7 of 7 Posts
I have a Green (as in the brand) induction kit for sale.
This is model SS019 designed for a Corsa VXR so its fecking huge but it will fit other models - i have it on my prefacelift 1.4 using a reducer so it should fit anything.
It is in AS NEW condition....original box with instructions and fittings. Reducer will also be included.
Size is 200 x 120 mm, inlet 70mm IIRC
RRP is well over £100 but i'll sell for £40 posted?
Pictured here on my 1.4...
You see any gains from this?
I know you dont see massive gains anyway but, Better throttle response?
As above really.
Perhaps if the weather is cold enough then you'll get better response - i've had it fitted while its been minus 10 or below round my way and it did give a bit more pull.
Normal weather then i'd say no better or worse than the standard airbox.
People have different opnions on them but either way you'll get a nice grunty noise with it fitted! :)
1 - 7 of 7 Posts
