my amp which is powering up two subwoofers has been powering up properly!!!!
the light on the amp keeps flashing. i have checked the earthing, remote cable and the power but didnt find anything!!!
this happened when i connected another powerful amp and 2 subs for 2 days on trial basis and the cables i think were not powerful enough to handle it.
i have not blown the subs or the amps they are working fine, i reckon it is my cables but was wondering if u guys can point it out to me instead of changing the wiring in the car!
cheers
aramis
The flashing could mean protection mode. Does it have a protection light on it ?
Re-check the earthing mate as this is usually the problem, maybe move it to a different earthing point and see if that helps ?
Does the amp power on when you turn the head unit on and vice versa ?
i dont think it has a protection mode light mate.... i have two points of earthing on the car.tried both but no luck!
im not sure if the amp comes on as the light keeps flashing as if there is a loose connection somewhere!!
could it be that the remote cable is fooked or the power cable or the earthing??
it cant be from the headunit part of thing can it?
